Example Code
Check memory usage of current process using SystemAPI
Code and Documents
If you want to check memory usage of your system it's quite easy. You can just use LabVIEW System API. But if you want to see how much memory is used by your single process that you're running you have to use Windows System API.
An example likt this is attached below. Use this to check if your application is getting close to the maximum memory usage in your system or not.
This example is written for LabVIEW 32 bit but with easy modification you can use it also for 64 bit apps.
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
Comments
ElsDph
Member
Member
on
How is it possible to get the memory usage of another process (*.exe)?
nanocyte
Active Participant
Active Participant
on
You can improve performance ~100,000x if you store the process reference:
JonathanMATech
Member
Member
on
I tried the example by nanocyte in a while loop but it does not appear to show updates.
Why is the output of this different than than any output of LabVIEW 2020's new Get Memory Status VI? And why are both different from all of task manager's indications?
Contributors
