This example covers how you check if a particular file is open on your computer in LabVIEW. You also can use this functionality to share a single file between multiple LabVIEW users or an .exe.
Description-Separate-2Most of the File I/O VIs and Functions will give you an error if the file in question is open when the VI executes.
To check if a file is open, you can use a File I/O function, such as Open/Create/Replace File, and evaluate the error code to see if the file is open. For example, Open/Create/Replace File gives error code 5 if you attempt to open a file that is already open.
See the attached VI for an example.
Determine the Active Window in LabVIEW
Related-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
Note: The solution described is not guaranteed to work if a 3rd party application has opened the file. This is because some processes may create a temporary copy of the file during open/edit (non-locking), and only open the original version of the file during save. This example is only suitable for applications that use locking mechanisms (i.e. open and reserve the original file).
