Example Code
Check Memory Size on High-Speed Digital I/O (HSDIO) Devices.
Products and Environment
    Hardware
  • Modular Instrumentation
    Software
  • LabVIEW
    Driver
  • Other
Code and Documents
Overview
    This VI opens an HSDIO session using NI-HSDIO to check the onboard memory size for your 654x, 655x, or 656x device.
Requirements
    Software
        LabVIEW 2012 (or compatible)
        NI-HSDIO driver which is compatible with your hardware and version of LabVIEW
    Hardware
Instructions
    1.Select the resource name of your devices. An array of devices may be selected if necessary.
    2.Run the VI.
    3.Results are displayed on the front panel which tell you the Serial Number, Total Acquisition Memory Size, Total Generation Memory Size, and the Mbits/ch of your device.
Best Regards,
Jignesh Patel
Principal RF Software Engineer
