Example Code
Check Input String for File/Path in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to verify if an Input String contains a path or a file name.
Description
This VI verifies if an Input String contains a path to a folder, a path to file, both or none. It uses a combination of cases structures and it searches special characters that are contained within a path to a folder or a file. It searches the character “/” for identifying if it has a reference to a folder and the character “.” for identifying if it has a file name.
The code can identify if both the path and the file name are or not present. Depending on the results of the search it can pop up a dialog with one of the following four messages:
1. Filename
2. Path
3. File name and path
4. No file name or path
Requirements
LabVIEW Base Development System.
1. Load the attached VI named “Check Input String for Path-File LV 2012 - NI Verified.vi” as a subVI.
2. Be sure to place a valid string in Input String control.
3. Run the VI.
A_Ryan
AES
