Example Code
Changing 64 Element Boolean Array with 8 Booleans and a Enum in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to take in 8 Boolean values and place them into a 64 indexed 1D array.
Description
This VI will take in 8 Boolean control values and update the values of a 64 indexed 1-D array of Booleans. In order to choose where the 8 Values will be placed in the array, the Enum called "Choose Which Section of Eight Booleans to Change" will allow you to select each 8 section of the array.
Requirements
LabVIEW Base Development System.
1. Run the VI.
2. Choose the section of the 64 indexed Boolean 1-D array from the enum named: Choose Which Section of Eight Booleans to Change.
3. Change the values of the Boolean # controls.
4. Hit the Change Values Boolean Button.
Jim St
RF Product Support Engineer
