Example Code
Change orientation and print Word document programmatically with ActiveX
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to set an orientation and print a Word document.
Description
Changing the properties of a Word document can be useful if you want to customize a document but need a function not already available in report generation VIs. In this example, the orientation of a VI is changed from portrait to landscape and is then sent to the printer.
Requirements
LabVIEW 2012 (or compatible)
1. Create and save a test document.
2. Point the file path of the VI to your test document.
3. Check the ending orientation of the printed document.
4. Run the program.
