Example Code
Change and Invert Y Scale Programmatically in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
 Overview
This code allows to programmatically revert the maximum and minimum values of the Y scale in a graph.
Description
The intent of this code is to programmatically not only revert the maximum and minimum values of a graph but will also show how we can modify programmatically those values and the increment of the scale.
Requirements
LabVIEW Base Development System (or compatible)
  1. Run the VI
  2. Set the desired values for the Y scale in the graph
  3. Use the Flipped control to swap the order
  4. Use the Stop button to finish execution
Sincerely,
Jason Daming
http://www.ni.com/support
