Overview
This example shows how to programmatically change the colors of the markers using property nodes.
Description
Through this example VI, you can see how to use property nodes to change the colors of the markers.
Requirements
All of this can be done via the front panel, also. To change the colors, the Marker Spacing needs to be set to Arbitrary.
VI Block Diagram
Can I change the color ramp of Rotated = 45 degrees???
Hi Tallahassee,
Unfortunately, I do not think this is currently possible, or at least I have not found a way to do this. I have seen other implementations that cover up a larger square's corners to make it a diamond shape, but I do not think this is what you are looking for.
Best of luck!
