Example Code
Change Line Names on Digital Waveform Graph Programmatically
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
The example demonstrates how to alter the line names of digital waveforms within the block diagram of the LabVIEW
Description:
This simple VI would shows you a basic flow to change the digital line names
Steps to implement or execute code
To implement this example:
  1. Change the channel parameters as needed
  2. Run the VI
  3. (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
  1. Install the required software.
  2. Connect the DAQ hardware that supports the DIO features
  3. Confirm the connection with the MAX with TestPanel
  4. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Digital Input Output Module
Rohan B
Comments
aschipfl
Member
Member
on
Is there also a similar way to set/change the names of busses in digital waveform graphs?
