Example Code
Change Cursor Appearance while Hovering Over Controls During Runtime
Code and Documents
Description
Introduction
As of LabVIEW 2011 SP1, the default cursor on the Front Panel during runtime is displayed as the familiar hand icon. However, you can programmatically change the mouse appearance with the Set Cursor VI. There are several use cases for this functionality. One example, is that you may want to provide the user with feedback when the mouse is over an active control.
Implementation
The code below shows how you can use an Event Structure to register when the mouse enters the proximity of a Front Panel control. The integer value input on the Set Cursor VI dicates what the appearance of the cursor will be. LabVIEW Event Structures have cases for the various types of controls to detect specific mouse events.
Closing
The current example does not programmatically add cases for all front panel objects. Feel free to expand upon the usability of this example or find other ways to implement Set Cursor!
KyleP
Contributors
