Example Code
Change Control Color When Threshold Value Exceeded in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code snippet functions well as a subVI to specify a threshold value.
Description
This code snippet functions well as a subVI. It allows the user to specify a threshold value, and when that value is exceeded a control or indicator on the front panel will change color. For instance, if an overtemperature condition occurs in an oven (actual temp = 100 degrees, overtemperature set to 90 degrees) the temperature indicator may change from green to red. Enjoy!
Requirements: LabVIEW 2012 (or compatible), Hardware: none.
Steps to Implement or Execute: Use as a subVI in your code. Connect the corresponding values.
Additional Information or References:
David G
Sales Engineer - SE Michigan & N Ohio
