Per scaricare il software NI, compresi i prodotti illustrati di seguito, visitare il sito ni.com/downloads.
Overview
This VI allows you to programmatically change the color of tabs on a front panel tab control. It is ideal for high-lighting the selected tab
Description
In certain applications, the user wants to highlight the tab control, when pressed. This VI implements changing the color of Tab control programmatically, using Event Structure. Whenever a Tab control press, a value changed event occurs, and then changing the color to its new value (color)
Requirements
LabVIEW Full Development System 2012 or compatible
1.Run the VI
2.Switch between the Tab controls
3.Observe how each Tab changes its color
4.Press the stop button, to sop the VI
This VI is using Event Structure
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
Description-Separate-2
Il codice di esempio scaricato dall'Example Code Exchange nella NI Community è concesso in licenza con la licenza MIT.
Hello I don't know how to apply your solution for detect any control change in tab_control page for every page?
Could you help me please?
Dennis
