Overview
Demonstrates how to use Property Nodes to change boolean LED indicator colors and text.
Description
This example uses Case Structure to select the color cluster constant based on the number of iteration of While Loop. The cluster is a cluster constant with two color box constants in it. The Colors property in Property Node takes in a 1D array of a cluster with two elements. Iteration number is converted into a string and displayed using BoolText.Text property in Property Node. While Loop is used to run the program until the number reaches 30.
Requirements
LabVIEW 2012 (or compatible)
Additional Information or Resources
VI Block Diagram
