Example Code
Can I Rotate a LabVIEW Front Panel Indicator?
Products and Environment
    Software
  • LabVIEW 2017 SP1 Full
Code and Documents
Description
This example covers how to rotate a string or numeric indicator 90 degrees on the front panel.
How to Use
Within LabVIEW, you are only able to set the vertical alignment of a label, caption, or free label. See error 1453 in General LabVIEW Error Codes
There are possible workarounds, depending on your coding goals. An example VI is attached to this article.
Additional Information
Feel free to make feature requests in the LabVIEW Idea Exchange forum.
Contributors
