Overview
This code uses the Python 2.7, the pywin32 module, and the active TestStand Engine in order to create a new sequence callled "PythonSeq.seq" in the users public directory. TestStand can be called from any language that supports ActiveX calls. This can be achieved iin Python using th Pywin32 module found here: pywin32
Note: The offically supported languages for the TestStand API are some .NET based languages, LabVIEW, and C. Calling the TestStand API in Python has not been fully tested and is not supported. This example is meant to be a starting point.
Description
The script uses the pywin32 module to get a reference to the TestStand engine. Once we have the engine object, we can create any of the other TestStand objects that we may need. At this point, the calls to the TestStand API will be very similar to what they would be in a .NET based language. First, a sequence file is created, then we get a reference to the MainSequence and insert a MessagePopUp step. After that, we set the value of the step, set the name and then save that sequence file to the Users Public Directory.
Requirements
1. Download pyscriptTS.py
2.Run it in the Python environment of your choice
3.Check C:\Users\Public for sequence named "PythonSeq.seq"
4.Open that up in TestStand and verify that it has a message pop up step that says "This sequence was created from Python 2.7!"
