Example Code
Calling an SQL Stored Procedure Using the Database Connectivity Toolset
Products and Environment
    Software
  • LabVIEW Database Connectivity Toolkit
Code and Documents
Description
This example calls stored procedures in SQL Server using the LabVIEW Database Connectivity Toolset. The VI uses two methods to call the built-in stored procedure sp_helpuser -- one method uses parameters and the other does not.
Related Links:
LabVIEW Database Connectivity Toolkit, now included with LabVIEW Professional
