Overview
This VI shows how you can use the expression nodes and linear algebra VIs to calibrate thermistors based on at least 4 different calibration points.
Description
This vi can be used to find the Coefficients of the Steinhart-Hart equation which is useful when calibrating thermistors. The Steinhart-Hart equation for modeling thermistors can be formed into a linear equation that can be solved for its constants A, B, C and D. This example does not go over how to obtain the 4 calibration points.
Note: Steinhart-Hart Equation 1/T = A + B*ln(R) + C*ln(R)^2 + D*ln(R)^3, where T is the temperature of the thermistor and R is the resistance of the thermistor.
Requirements
VI Snippet
