Example Code
Calculating BMI Using Case Structures in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI shows how to use case structures to calculate BMI.
Description
This code taks in a patient's height and weight, then, using case structures, outputs the patient's status.  Depending on the BMI, the patient is either underweight, normal, or overweight.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Enter the patient's weight into "Patient's Weight."
  2. Enter the patient's height into "Patient's Height."
  3. The Status and the BMI for the patient will be output in the "Output Information" section.
  4. The program will run continuously and patient values can be entered until the stop button is pressed.
VI Snippet
