Example Code
Calculate Prime Number in LabVIEW
Products and Environment
    Software
  • LabVIEW MathScript RT Module
  • LabVIEW
Code and Documents
Overview
Demonstrates how to calculate 1001st prime number using MathScript Node.
Description
This program is to solve Project Euler Problem Number 7: By listing the first six prime numbers, what is the 10001st prime number? The example uses iteration number as the number to be computed. MathScript Node is used to determine whether the number is a prime number. The prime numbers identified is built into an array. The program stops when the prime numbers elements reach 1001. The last prime number will be displayed.
Requirements
LabVIEW 2012 (or compatible)
MathScript RT module
  1. Run the program
  2. The program takes a few seconds to compute the first 1001 prime numbers
  3. The 1001st prime number will be displayed
Additional Information or Resources
VI Block Diagram
Rob W.
