Example Code
Calculate Delta X with cursors on a graph
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
To demonstrate how calculate delta X between two cursors in waveform graph
Description:
The purpose of this example is so you can programmatically calculate the delta X on a graph using the cursors.
Steps to implement or execute code
To implement this example:
  1. Run the VI
  2. Adjust the cursors
To execute this example:
  1. Install the required software.
  2. Run the VI
Requirements
Software
LabVIEW 2012 or compatible
Hardware
Miriam
Field Applications Engineer
NI Colombia
CLD
