Example Code
Calculate Actual Clock Rate
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code calculates the actual clock rate when dividing down an 80 MHz clock.
Description
When you want the sample clock rate of a particular task to be different than the 80 MHz Timebase of a device, the device must divide down the 80 MHz Timebase. This is done with an integer divisor. Consequently, the actual sample clock rate will not be exactly what is desired. This VI allows you to see what the actual sample clock rate will be without using the DAQmx Timing property node with the SampClk.Rate property.
This example can be modified to calculate the actual sample clock rate for other Timebases, such as a 20 Mhz Timebase.
Requirements
Software
  • LabVIEW 2012 or compatible
There are two portions of this VI. You may calculate the actual clock rate based off of a desired clock rate or based off of an integer divisor.
 **This document has been updated to meet the current required format for
David B.
