Overview
The program encode and decode the string
Description
To use the program, type a string into the String box. With the toggle set to encode and the Magnitude of Shift control set to non-zero, run the program; this will result in an encrypted string. To decode a string, type or paste the encrypted string into the String box. With the toggle set to decode, run the program with the same Magnitude of Shift value that was used to encode the string; this will reveal the original string.
Requirements
1.Input the String
2.Configure the button 'Decode' or 'Encode'
3.Run the VI Additional Information or References
VI Block Diagram
Your 2009 version is saved in 2012.
