Example Code
CDAQ-9178 Count Digital Events Without Digital Module
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This example shows how to create a count digital events task by accessing the CDAQ-9178's onboard counters without a digital module.
Description
Instead one of the 2 onboard PFI lines will be routed to the onboard counter.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI cDAQ-9178
  1. Choose one of the onboard BNC trigger connections to act as PFI lines where the signal to be counted will be inputted.
  2. Choose the onboard counter.
  3. Run the VI
Tejinder Gill
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
