Example Code
CANopen SDO example for USB CAN
Products and Environment
    Hardware
  • CAN Interface Device
Code and Documents
Description
Functional Description
This VI is an example of how to read and write to a CANopen network using SDO. This is an extension of the library from the DevZone article, CANopen Basics for USB 8473, that has some more examples on using SDO and PDO.
If you are using a non-USB National Instruments CAN interface, it is STRONGLY recommended to use the NI CANopen LabVIEW Library (not compatible with USB-CAN devices).
Required Software
Helpful Links
CANopen - Wikipedia, the free encyclopedia
CANopen USA
Update
Added the modified llb file to include this VI along with the new USB_CANopenWriteSDO+.vi
Peter Flores
Comments
gom790
Member
Member
on
I can't find out where USB_CANopenWriteSDO+.vi is .....
Please, let me know where file is ?
pflores
NI Employee (retired)
on
That VI is in the library available at CANopen Basics for USB 8473.
Sorry for the confusion!
Peter Flores
gom790
Member
Member
on
I search for the file in the library at CANopen Basics for USB 8473 but i don't look for the file,,,....
I think that only USB_CANopenWriteSDO. vi exist. not USB_CANopenWriteSDO+
Could you give me that file or upload to this website ?
Sorry for ask you that problem....
pflores
on
You are absolutely right
I forgot that I needed to create this new VI to support the new finctionality. The attached llb file should include everything you need.
Peter Flores
gom790
Member
Member
on
Thank you for uploading this file .....
Chris2000
Member
Member
on
I have Problems with the Subvis. In there are DLL calls but i don't know where the DLL are ?
ncConfigCANNet.vi
DLL ncConfig ?
