Example Code
Button Press Event Record to Data File using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Use this VI to acquire a signal from a DAQ device, log signal in an ASCI file and detect and log if a button is pressed.
Description
This VI records a button press event to a log file (in this case, a simple text file) in line with the the data being captured. The data somewhat simulate what you get when using a Write To Measurement File Express VI in that it records the timestamps and other metadata in the process at the beginning of each iteration.
Requirements
  • LabVIEW 2012 (or compatible)
  • DAQ device
1. Run VI
2. Press Ok button
3. Stop the VI
4. Look at example.txt in the VI directory
Block Diagram
Button Press Event Write to LogFile LV2012 NI verified.pngButton Press Event Write to LogFile LV2012 NI verified.png
Jeff | LabVIEW Software Engineer
Comments
Todd S.
NI Employee (retired)
on
Great stuff!  Thanks for posting!
Todd S.
LabVIEW Community Manager
