Example Code
Build Ramp Waveform
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code appends two voltage ramps.
Description
Sometimes, we need to test our instrument by feeding it with specific signals to see its response. Or maybe we want to have it run through a series of values over a long period of time without having to worry about it. This creates two voltage ramps and then appends them together. It is a simple start and is built for easy modification.
Requirements
LabVIEW 2012 (or compatible)
1. Set the initial and final voltage values, with the final time for both ramps.
2. Run the VI.
ColeR
Field Engineer
