Example Code
Build Array in Excel Using MathScript Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Here is some example code that allows you to build and array and append it to an Excel file.
Description
This VI will generate an array of 10 random numbers and append it to a file in excel every second. After you stop the VI, open the Excel file named 'append' and you will be able to see your data. Excel cannot be open when this VI is running, otherwise you will get an error. Also, if you don't change the filename, the data is not cleared and will be overwritten.
Requirements
  • LabVIEW 2012 (or compatible)
  • MathScriptRT Module 12.0 (or compatible)
  • Run the program
VI Snippet
Stephanie A.
Americas Marketing Manager
