Example Code
Bring Excel 2010 Window to Front Programmatically
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI shows an alternative way to  bring the Excel window to the front of the screen
Description:
In Excel 2010, the ActiveX calls that bring the Excel window to the front of the screen do not work.  This VI shows an alternative way to do this using the Windows API.
Steps to implement or execute code
To implement this example:
  1. Run the VI
  2. (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
  1. Install the required software.
  2. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
Hardware
Drew T.
Camber Ridge, LLC.
Comments
Dblack
Member
Member
on
Thank you. That was very helpful!
