Overview
This example is a subVI that can will give a boolean true during a user-specified time range each day.
Description
This code could be used in a variety of applications that run for extended periods. This example was originally created for a NI Discussion Forum Thread. The Format Date/Time String function is set to work on a 24 hour clock, but can be changed to a 12 hour clock by using the format string "%I:%M:%S".
Requirements
1. Download the attached VI
2. Drop it into LabVIEW and create control architecture to set the time limits
3. Use the boolean output to control logic-based architecture such as Case Structures
Front Panel
VI Snippet
User tried to use timestamps for the In Range and Coerce but couldn’t find a way to ignore the date included in the timestamp.
