Example Code
Boolean Indicator Value Change Count using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI demonstrate how to implement a count of how many distinct time a Boolean Indicator reads True
Description
Here is a brief description of the example:
By using a Case Structure controlled by the current boolean value and a Shift Register to store the Boolean value of the previous iteration, we can keep an accurate count of how many times the LED indicator changes from F to T.  This solution does not use an Event Structure nor any Local Variables, and is not blocking.
Requirements
  1. LabVIEW 2014 (or compatible)
  1. Download Boolean LED Count.vi
  2. Run the vi.
  3. Click the Control.
  4. The count will be displayed.
VI Snippet
Ashley G.
Principal Applications Engineer | RF & Wireless Communications
Comments
crossrulz
Knight of NI Knight of NI
Knight of NI
on
You can do this a lot simpler by using the Boolean Crossing PtByPt.vi
