Example Code
Boolean Array Case Selector in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example gives an efficient way to handle all possible combinations of multiple boolean input values.
Description
This VI demonstrates one way to organize your logic for determining which case of a case structure to execute. It becomes very useful when you have to handle every possible combination of multiple boolean values. The number of possibilities is 2^n, so with 4 boolean values there are 16 possible combinations of those values.
Requirements
LabVIEW Full Development System 2012 or compatible
  1. Run the VI
  2. Click on the Input Array control to change the binary values and selected case Messages
Note that the functionality of the case structure makes it possible to handle multiple possibilities with one case very easily. See the LabVIEW help for the case structure for the syntax for having a case handle both close and open ended ranges and lists of values.
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
