Example Code
Bode Diagram Plot Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows a quick way to create a filtered sine wave and plot its bode diagram plot.
Description
A Bode plot shows the magnitude vs frequency response of a circuit.  This example VI generates a sine wave sweep, sends it though a (software) filter, and plots the frequency response of the filter.  After the sine wave sweep completes the -3dB cutoff frequencies are calculated.  This VI could easily be modified for use with DAQ hardware and a physical circuit.
Requirements
  • LabVIEW 2012 (or compatible)
  • Select the max frequency and filter band width.
  • Run the program
VI Snippet
