Example Code
Binary Headers in Binary Files Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Demonstrates how to write and read from a binary file that makes use of header information above its data set.
Description
To read binary files you need to supply the information of the data type representation, normally a double or integer for the data, while the header should be a string. This example shows an easy way to add a string as a header to a binary file and still using an integer for the data.
Requirements
LabVIEW 2012 (or compatible)
  1. Choose File Path for binary File
  2. Run the VI
VI Block Diagram
Will
CLA, CLED, CTD, Former CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
