Example Code
Bidirectional Rotation of a 2D Array by a Multiple of 90 Degrees
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to rotate a 2D array.
Description
This subVI utilizes the Transpose 2D Array.vi and the Reverse 1D Array.vi (with an auto-indexed for loop) to rotate a 2D array clockwise or counterclockwise respectively.
Requirements
LabVIEW 2012 (or compatible)
1. Enter the desired input array into the Array control, or use the default values.
2. Select the direction on the Rotation Orientation toggle and the magnitude on the Rotation enum.
3. Run the VI and observe the rotation.
Front Panel:
Block Diagram:
Clockwise:
Counterclockwise:
