Overview
This program was created to allow a user to modify the names or a large number of files without the need of renaming every individual item.
Description
The code reads from a user selectable directory on disk and gets the name of every file in that specific folder. The user can then select a destination path, base name and extension for the new files. The files are renamed based on date order.The 2D sort function was modified to accept strings rather the DBLs.
Please note the Sort 2D array function was not created by myself and was taken from an example on the community:
https://decibel.ni.com/content/docs/DOC-12264
Requirements
Additional Information or Resources
VI Block Diagram
