Example Code
Base number converters using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI demonstrates how to convert between base 10 and base N numbers using unsigned integer arrays.
Description
Here is a brief description of the example:
"ConvertToBase.vi" takes a base 10 value and converts it into an array that represents the number in a differing base. From base^0 to base ^ i in length depending on how large the number is. This is achieved through iterative Quotient & Remainder operations, outputting the remainder into an auto indexed array, with the Quotient being passed through a shift register into the next iteration.
The math is based on the example found here: https://www.mathsisfun.com/base-conversion-method.html
"ConvertFromBaseTo10.vi" reverses the process and produces a base 10 integers from an array of base powers. This applies an iterative summation of the value of each index in the array multiplied by the base ^i value.
Requirements
  1. LabVIEW 2015 (or compatible)
  1. Recommended to use both subVIs together with "Convert to Base.vi" outputting to "Convert From Base To 10.vi" so that the format can be observed.
  2. Any further explanations required please ask in the comments.
VI Snippet
Convert From Base To 10.vi:
Convert From Base to 10 2015 NIVerified.pngConvert From Base to 10 2015 NIVerified.png
Convert to Base.vi:
Certified LabVIEW Architect
Comments
PWoodward
NI Employee (retired)
on
For larger applications I would suggest taking out the property node in "ConvertFromBaseTo10.vi" as it can slow down processes with multiple iterations.
