Example Code
Backspace Display Example
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This is a simple illustrates how to display a backspace character as a physically deleted character using LabVIEW.
Description
This code uses a Search and Replace string function to find the backspace character. It then splits the string into two substrings that do not include the backspace character. Finally, it recombines the two substrings back together to display the original text with the backspace implemented. There are some limitations to this code. As it is currently setup, it will only operate correctly if there is just one backspace character in the input. It could be modified to loop through and check for all backspace characters if you desire. It is also important to note that the controls and indicators on the front panel display are in 'Slashcode Display' mode to make the backspace character visible. You can change this mode by right clicking on the controls and indicators and selecting Normal Mode.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open the VI and Run
  2. Modify the input code to your own text and watch the backspace character execute in the Output indicator
VI Block Diagram
