This example shows how LabVIEW can:
powershell.exe.IWshShell.AppActivate.IWshShell.SendKeys.It is a straightforward way to integrate PowerShell commands into LabVIEW, but for robust automation, redirecting Standard Input/Output is generally preferable because it removes the dependency on window focus and allows LabVIEW to directly capture command results.
Note: The VIs are built using LabVIEW 2026 Q1.
