Example Code
Automatically Store a Selected Folder and Create New File Path Each Time Program Runs Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows a way to automatically create files within a folder each time a LabVIEW program is ran.
Description
This particular case involves a non-repetitive test, but one in which the operator will keep the VI open between tests. Therefore, feedback nodes may be applied to store a selected folder between each execution of the VI, thus allowing paths to be stored without the use of shift registers and a looping structure.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the VI.
  2. Open the VI.
  3. Run the VI with the Auto/Manual switch in the OFF position
  4. Choose or create a folder
  5. Run the VI repeatedly and notice a new file path is created each time the VI runs
VI Block diagram
Matt J - NI Tools Network
