Overview
This example VI demonstrates how to programmatically generate files with names numerically increasing based on loop iteration.
Description
In LabVIEW you are able to concatenate strings and give custom names to files based on loop iterations. In this example a while loop is used to give consecutive names to custom-generated files, based on the iteration counf of the while loop and native LabVIEW APIs, which allow the user to easily convert number data types to a string data type. The output is printed in a path indicator and visualized on the front panel.
Requirements
VI Block Diagram
