Overview
This example VI is a basic audio analysis function with a display of raw sound data in the time domain, an FFT of that data, as well as a power spectrogram.
Description
This example is a basic audio analysis function with a display of raw sound data in the time domain, an FFT of that data, as well as a power spectrogram. The VI does not require the Signal Processing toolkit, which has a spectrogram built in natively. And it is designed to use the signal from your Windows computer's microphone input. You will have to configure the code to match the sound device as it is set to use device 0 by default.
The code has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
Requirements
- LabVIEW 2012 (or compatible)
- Download the attached folder to your computer
- Open the VI " Audio Analysis with Sound Card 2012 NIVerified.vi"
- Run the program
VI Snippet
