Overview
Performs logic to re-arrange the Children[] array that follows the below naming convention so the array will list the variables in numeric order.
Description
When using the naming convention of Variable_Name01, Variable_Name02, ...Variable_Name10 for network shared variables and the Variable Container property node to access the array of the Children[] of a library, the first ten variables will always be an the last elements of the array. The output does not equal the variable listing in the Project Explorer. This VI performs the logic needed to arrange the Children[] array so the elements will be in numeric order.
Requirements
LabVIEW 2012 (or compatible)
Additional Information or Reference
