Example Code
Archived: NI-DAQmx: Analog Output Frequency Sweep in LabVIEW
Code and Documents
Overview
This document has been archived and is no longer updated by National Instruments.
This example generates a continuous output waveform on an E-Series or M-Series board. The frequency of this output waveform is swept across a specified range logrithmically in a number of discrete increments defined by the user. Custom_Sweep is the main VI that generates the waveform and Create_Log_Frequencies is a subVI called by Custom_Sweep to get the logarithmic frequency array.
Contributors
