Example Code
Archived: Language Interface: 16-bit Microsoft Professional BASIC for DOS
Code and Documents
Overview
This document has been archived and is no longer updated by National Instruments.
This is the GPIB language interface for Microsoft Professional BASIC (version 7), a DOS programming environment for creating 16-bit applications. Download the Basic7.zip file (in the example.zip file, below). This file contains the declaration file MBDECL.BAS, the language interface file MBIB.OBJ, and some sample programs.
How to Use the Microsoft Professional BASIC Language Interface:
I. Overview
The 16-bit GPIB language interface for Microsoft Professional BASIC contains the following files:
MBDECL.BAS: Microsoft BASIC program declarations
MBIB.OBJ: Microsoft BASIC language interface object module
If you have the GPIB Software for DOS, the Professional BASIC language interface and the sample applications are located in the directory called \BASIC7 (where is where the GPIB software for DOS is installed).
II. Items to Include in Your GPIB Application
You must include the following line at the beginning of your application:
'$INCLUDE: 'MBDECL.BAS'
Next you need to link the mbib.obj file to your application.
III.A. Compiling, Linking, and Running from the Professional BASIC Environment
Before you can run an application, called yourprog, from within the Professional BASIC interactive environment, follow the steps listed below:
1. From the DOS command line, create an object module library called MBIB.LIB, by typing in the following:
LIB MBIB.LIB + MBIB.OBJ;
From the DOS command line, to create a QuickLibrary called MBIB.QLB that is linked with the MBIB.OBJ language interface, type in:
LINK /Q MBIB.OBJ,,,QBXQLB.LIB;
[NOTE: Please remember to include the three commas between MBIB.OBJ and QBXQLB.LIB.]
2. To invoke the BASIC environment where you can run an application called yourprog, type the following on the DOS command line:
QBX YOURPROG /L MBIB.QLB
III.B. Compiling, Linking, and Running from the DOS Command Line
To run an application, called yourprog, from the DOS command line, follow the steps listed below:
1. To compile the BASIC application called yourprog, type in:
BC YOURPROG;
2. To link the BASIC application, called yourprog, with the MBIB.OBJ language interface, enter the following:
LINK YOURPROG MBIB;
3. To run the application, called yourprog, from the command line, type in:
YOURPROG
Contributors
