This is the GPIB language interface for IBM Pascal, a DOS programming environment for creating 16-bit applications. Download the Ibmpas.zip file (in the example.zip file, below). This file contains the declaration file DECL.PAS, the language interface file PIB.OBJ, and some sample programs.
How to Use the 16-bit IBM Pascal Language Interface:
I. Overview
The 16-bit GPIB language interface contains the following files:
DECL.PAS: Pascal declaration file
PIB.OBJ: Pascal language interface module
II. Items to Include in Your GPIB Application
You must include the following line at the beginning of your application:
{$INCLUDE: 'DECL.PAS'}
Next you need to link the PIB.OBJ file to your application. The PIB.OBJ file must NOT be the first file named in the link list when linking with the application program.
III. Note to IBM Pascal Users about Names
The board or device name must be of type nbuf (array[1..7] of char). nbuf is defined in DECL.PAS. Use blanks to pad the name.
Example:
var bdname : nbuf;
bdname := 'gpib0 ';
