Example Code
Analog Output and Digital Input using DAQmx
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
The example is to demonstrate how to configure analog output and digital input in the same VI
Description:
The VI is to show you how would you configure the two channel of analog output and digital input at the same time within
the same VI
Steps to Implement or Execute Code:
To implement this example:
  1. Define the Channels (Digital Input and Analog Output)
  2. Set the value of the parameters as needed
  3. Run the VI
  4. (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
  1. Install the required software.
  2. Connect the DAQ hardware that supports the AO dan DIO features
  3. Confirm the connection with the MAX with TestPanel
  4. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Analog Output and DIO Module
