Overview:
This VI demonstrates how to generate an analog output voltage with a Multifunction Card (E-Series, M-Series, X-Series) and have the generation be based on a trigger.
Description:
This program is designed to ramp the voltage when a high digital level is received on the PFI0 line of the device. Using an initial DAQmx write to set the initial voltage level to the desired position, the user can then specify the high value as well as the step size of the analog voltage. To use this example for an application make sure to change the I/O Constant on the block diagram for the "Pause.DigLvl.Src". The VI will also display the current Voltage level as the loop is generating.
Steps to Implement or Execute Code:
Requirements
LabVIEW 2012 or compatible
NI-DAQmx 15.0 or compatible
Succinct example of using a pause trigger. Exactly what I needed to make a pausable ramp output vi. Thanks!
