Example Code
Amplitude Difference for Multiplot graph using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This VI compares the amplitude difference for multiple plots on a single XY Graph.
Description
This VI allows you to compare two amplitudes on 2 separate plots on a single XY Graph
It uses cursors and cursor properties to find amplitudes for a user defined X value and then subtracts them.
Additional Resources on cursor properties:
Adding Cursors to Graphs.
Requirements
  1. LabVIEW 2012(or compatible)
  1. Open the VI and run it.
  2. Use cursor legend to adjust the cursor position.
  3. Read the amplitudes difference value.
Block Diagram
Joel I.
