Overview
The example VI shows how to use the Numeric Text .Text property of a Time Stamp to change a compatible string directly into a Time Stamp.
Description
In the example below, the Format String property is used to set the expected format of the string for the conversion into a Time Stamp. Another option would be to use the Properties dialog box to customize the string format for the Time Stamp for easy modification depending on your string input, without needing to work directly with the format codes for Time Stamps (found at the link below in the steps section).
Requirements
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
