This VI shows how to use a horizontal slider to mimic the behavior of a scrollbar.
Waveform charts have built in scrollbars, but waveform graphs do not. You can use Property Nodes to achieve the same functionality on a graph.
The VI generates 1000 random numbers and plots them on both a chart and a graph. The chart scrollbar is visible, and you can scroll through the points, displaying 100 at a time. Using the value of a slider to control the minimum and maximum value of the display area on the graph, you can obtain the same effect as a scrollbar.
